Private VLANs and broadcast traffic separation
Sep 16th, 2006
http://www.mdh.se/netcenter/ct3690/ht-2005/forelas/Private_vlans.pdf#search=%22private%20vlan%22
((A VLAN on a network is a broadcast domain, and all of the hosts on that VLAN can communicate with the other members of the same VLAN.
PVLANs allow traffic to be segmented at the data-link layer (layer 2) of the OSI model, limiting the size of the broadcast
domain)).
Was it meant by word "traffic" in this phrase : "PVLANs allow traffic to be segmented ", broadcast traffic ? (i.e. Does that mean each PVLAN have its own broadcast domain ?)
rajinikanth Sat, 09/16/2006 - 06:22
  • Bronze, 100 points or more
VLANs create broadcast domains at layer2,
Usually broadcast domains are created by layer3 device but by using vlan we can create them at layer 2 device which are logical broadcast domains
Yes each VLAN Creates its own broadcast domain and to have communication between two vlans we need a layer3 device for this.
Raj
zillah2004 Sat, 09/16/2006 - 10:05
((VLANs create broadcast domains at layer2,
Thanks Raj, your explaination about VLAN, I have got no problem about VLAN.
My query was about PVLAN
