Warning message
ajagadee Sun, 09/17/2006 - 07:49
  • Cisco Employee,
Sam,
Depending upon what kind of 2924 you have, the IOS Version will differ.
For example:
Catalyst 2900 XL 4-MB switches run original edition software and do not support the 12.0(5)WC15 releases.
The 4-MB models are WS-C2908-XL, WS-C2916M-XL, WS-C2924C-XL, and WS-C2924-XL. These switches can only be upgraded up to Cisco IOS Release 11.2(8.10)SA6
So, if you have one of the above models, the latest version is 11.2(8.10)SA6
If you have 8-MB Catalyst 2900 XL switches and 16-MB Catalyst 2900 LRE XL switches, then you can upgrade them to 12.0(5)WC15.
Please refer the "Hardware Requirements" in the below URL for details:
http://www.cisco.com/univercd/cc/td/doc/product/lan/c2900xl/2935wc15/ol256211.htm#wp84866
So, do check the amount of memory (4MB or 8MB) on the switch and then download the appropriate version.
I hope it helps.
Arul
