Warning message
Difference of Lists
Sep 19th, 2006
I jut recently got to use a route map for the first time, pretty cool. When I was researching this issue I came across prefix lists, access-lists, and route maps. I know what access-lists do but what is the difference between all three of them. They seem to do the same thing so why use one instead of the other?
Overall Rating: 5 (3 ratings)
gpulos Tue, 09/19/2006 - 07:04
  • Blue, 1500 points or more
differences betweeen route-maps and ACLs are as follows:
(as you've stated, there are also a few similarities)
1) route maps use ACLs as matching criteria
2) ACLs perform an evaluation and provide a YES/NO answer; route maps can modify information associated with the route
(this is commonly used when redistributing routes from one routing protocol to another)
3) route maps can determine if a route is internal or has a specific tag; ACLs cannot.
please see the following link for more route-map info:
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a008047915d.shtml
prefix lists -
although there are a couple of similarities with ACLs, prefix lists differnces are as follows:
1) used to provide ip prefix filtering
2) can be configured to match an exact prefix or range of prefixes; ACLs cannot do this
3) prefixes use sequence numbers to determine which prefixes are read first and in what order. (lowest to highest sequence number); ACLs use top down reads.
please see the following link for more IP prefix list info:
http://www.cisco.com/en/US/products/ps6350/products_command_reference_chapter09186a0080454ced.html#wp1075035
leighharrison Tue, 09/19/2006 - 07:22
  • Gold, 750 points or more
Hi there,
Depending on what you wanted to achieve, you would use either an access-list or a prefix list to specify traffic.
For example, if you wanted to specify the ip network 192.1.0.0 with an access list you could use:-
access-list 1 permit 192.1.0.0 0.0.0.0 and with a prefix list you could use:-
ip prefix-list name permit 192.1.0.0/16
Depending on how your mind works you can use either. prefix-lists are used quite heavily in bgp configurations. Prefix lists can also get a little complex, where you can say:-
ip prefix-list name permit 192.1.0.0/16 ge 17 le 24
Which would mean anything in the 192.1.0.0/16 network with a mask greater than 17 bits, but less than 24 bits.
I personally prefer to use access-list, given the choice.
A route-map is set of conditions applied to redistribution in a routing protocol. This is the command ou use where you want to apply access-lists and/or prefix lists to routing policy.
For example:-
access-list 1 permit 192.1.0.0 0.0.255.255
ip prefix-list name permit 192.2.0.0/16
route-map example permit 10
match ip address 1
match ip address prefix name
router rip
redistribute static metric 3 route-map example
At the end of a route map is an explicit deny all - just like an access list. The access-list 1 is used to specify the network 192.1.0.0/16 and the prefix list is used to specify the network 192.2.0.0/16.
Then the route-map says to match any ip addresses that conform with the access-list or the prefix-list will be permitted. This is then applied when redistributing static routes into rip (in this example) and given a metric of 3.
In the route-map statements you can also have a choice of match-all or match-any, meaning that the route has to match all of the conditions in the route map, or any of them.
So, to summerise:-
Access-lists - used to specify traffic
Prefix-lists - used to specify traffic
Route-maps - used to set conditions for route redistribution
Hope that helps clarify,
LH
Please rate all posts
