Warning message
Block Streaming Audio
Sep 19th, 2006
Does anyone know how to block streaming AUDIO using the IOS firewall so that users can't listen to online radio stations?
Can you provide the commands?
Many thanks in advance.
beth-martin Mon, 09/25/2006 - 10:15
  • Bronze, 100 points or more
It is not possible using IOS Firewall.
you could only block based off of protocol, port, and source/destination IP.
If you want to block a specific application that employs streaming audio,you will have to do that at the application level (ie: Personal Firewall).
You may be able to disallow HTTP Tunneling to see if that will prevent it. However, I'm not sure what format the Internet Streaming Audio is using.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124cg/hsec_c
/part15/ch05/h_fwapc.htm
