Hunt/Line Group Configuration Issue
Answered Question
Sep 20th, 2006
Is there a way to configure a huntgroup to goto a voicemail box as the last member in CallManager 4.1(3)? When I setup the hunt list to goto the Unity line group, the call doesn't goto to the greeting prompt, it goes to the login/password Unity prompt
Correct Answer by Tommer Catlin about 10 years 11 months ago
The last memember should go to a CTI Device that is marked for forward to VM. If you have it setup another way, it may do some odd things with Unity.
You could also put in a rule in Unity for fwd or incoming calls for that number, go to xyz.
Overall Rating: 5 (1 ratings)
Correct Answer
Tommer Catlin Wed, 09/20/2006 - 09:46
  • Green, 3000 points or more
gpulos Wed, 09/20/2006 - 11:35
  • Blue, 1500 points or more
is the last entry in your huntList the first entry of the unity lineGroup? if not, make it so and try again.
(just thinking out loud here)
mtriebwa Wed, 09/20/2006 - 14:29
Figured it out, the pilot point configuration for the hunt group has been changed so the no answer field points to our voicemail pilot.
