Warning message
Common Services and Topology Services
Sep 20th, 2006
Under CS, I created User Defined groups for every building. This is how I group my network devices in every bulding.
Everything works great except when I view the network map under network topolgy of particular building. Some devices do not show up.
I've ran Campus Data Collextion several times to no avail.
BTW: Thanks to jclarke for the very fast responses.
Joe Clarke Wed, 09/20/2006 - 14:24
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Do the missing devices show up in any of the other views in Topology Services? What Data Collection filters do you have that could prevent Campus from managing the devices in question? Are you integrated with ACS, and if so, are the devices in question clients of the same ACS server, and in an NDG to which you have access?
wilfred malana Tue, 09/26/2006 - 08:22
No they do not show up in any map under topology services.
No filter under data collection.
No ACS integration.
Joe Clarke Tue, 09/26/2006 - 08:35
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
What types of devices do not show up in Topology Services? What is different about those devices vs. the ones that do show up (e.g. missing or different SNMP credentials, different network topology between devices and the CiscoWorks server, etc.).
If you still cannot isolate why the devices are not showing up in Campus Manager, you should enable core and corex Data Collection debugging. Then run a full Data Collection, then open a TAC Service Request and provide the ani.log as well as a sample device address/hostname and configuration which is missing.
wilfred malana Tue, 09/26/2006 - 08:50
The devices are 3750 stacks. Credential are correct. I do not see an obvious difference to tell you honestly. Unless I am doing something stupid that I will only realize later on.
By the way, I just enabled debugging with core and corex and am runnign DC right now. Thanks.
wilfred malana Tue, 09/26/2006 - 10:39
Ran a debug and found this in the output.
2006/09/26 09:48:25 Discovery ani DcrToCampusMap: Processing device: 499 IP: xxx.xxx.xxx.xxx
2006/09/26 09:48:25 Discovery ani DcrToCampusMap: License limit is -1
2006/09/26 09:48:25 Discovery ani DcrToCampusMap: Total no. of devices in WbuDeviceTable is: 1027
Under CS > Admin > Licensing my version of CM is Unlimited.
Joe Clarke Tue, 09/26/2006 - 10:41
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This is fine. -1 means an unlimited license.
wilfred malana Tue, 09/26/2006 - 11:46
My bad, the device actually shows up in Layer2 view.
How do I make it show up on CS/Customized Group?
Joe Clarke Tue, 09/26/2006 - 16:54
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You will need to make sure it matches your group's criteria. If you're using dynamic groups, and relying solely on rules, then the criteria values for this device may have changed, and thus it is no longer in the group you want it in. In that case, you can either add this device explicitly, change your ruleset, or aler the data on the device.
If you're certain that the device should be matched, but isn't, then you will need to enable OGS debugging. This is a more complex process than enabling Data Collection debugging, and thus you should contact TAC.
