How can I save group password in VPN3002 when tunnel to non-concentrator?
Sep 21st, 2006
Hi All,
It seems that after 4.1 version of 3002 Hardware client, the group and user password can no longer save in the 3002. And in my network environment, the remote branch office is using 3002 and it will power-off during non-office hour. After power on again it can no longer automatically connect to main office's Cisco 2811 router via VPN tunnel. So does this have any solution? Thanks!
Jason
Best rgds,
thomas.chen Wed, 09/27/2006 - 05:16
  • Silver, 250 points or more
The problem which you are facing is not a security flaw, Instead this is a normal behavior on later releases of the code of the 3002.
