Warning message
QoS apply problem!!!!!
Sep 22nd, 2006
Hi friends,
I have this QoS configuration:
class-map match-all FTP
match protocol ftp
policy-map limitFTP
class FTP
shape average 1000000
policy-map parent
class class-default
service-policy limitFTP
map-class frame-relay test
service-policy output parent
interface serial1/2
frame-relay traffic-shaping
interface frame-relay 1/2.X
frame-relay interface-dlci X
class test
When I apply the last command ( class test on the sub-interface) I have this error:
GTS: Can be enabled only at the first level.
What is this? Can someone help me?
Thank you very much
mheusinger Tue, 09/26/2006 - 07:11
  • Green, 3000 points or more
you configure a nested policy-map, first level being "parent" second level being "limitFTP". With this construction you should use your shaper in the parent policy, as GTS has to be enabled on first level. In case you want to just limit FTP, your config could look like this:
match protocol ftp
policy-map limitFTP
class FTP
service-policy output limitFTP
interface serial1/2
class test
In case you want additional QoS features, then name them and we can adjust the policy to your needs.
Hope this helps! Please rate all posts.
Regards, Martin
bascheew Fri, 07/06/2007 - 22:38
How would this be done on a Dialer interface? The command:
map-class dialer class_name
doesn't give me the option to then apply a service policy to the map-class. Any other way to do this?
