WCCP in 4507R
Sep 23rd, 2006
Hi ,
I'm trying to configure 4507R ( 12.2(31)SG )to run WCCP as shown in the attachments.
1- I enable WCCP globally
2- In users VLAN redierct HTTP in .
3- In bluecoat configuration is
wccp enable
wccp version 2
service-group web-cache
forwarding-type l2
password cisco
home-router X.X.X.X ( L3 port IP in 4507R).
interface 0
end
I got the following error
4d02h: WCCP-EVNT:S00: Here_I_Am packet from 10.25.50.1 w/bad rcv_id 00000000
ariela Sun, 09/24/2006 - 01:34
  • Silver, 250 points or more
Looks like the I_SEE_YOU packets never reaches ProxySG. Perhaps you have a
local firewall dropping the packets?
WCCP is using UDP port 2048 for the control channel.
Then be sure that the ip of
wccp router is correct.
Then try without:
forwarding-type l2
password cisco
and see the doc at
http://www.bluecoat.com/downloads/support/BCS_tb_implementing_WCCP.pdf
Please let me know
Andrea
katab Thu, 09/28/2006 - 03:54
Thank Andera ,
1- There is no firewall
2- I can Managet the Bluecocat from Users VLAN .
3- I tried with no password but no luck.
4- Cat4507R does not support GRE that is why I'm using forwarding-type l2 .
5- CoreSW1#sh ip wccp web-cache detail
WCCP Cache-Engine information:
Web Cache ID: X.X.X.X
Protocol Version: 2.0
State: NOT Usable
Redirection: L2
Packet Return: L2
Packets Redirected: 0
Connect Time: 00:02:11
AssigSW1#
Where X.X.X.X is the Bluecoat IP address.
