Warning message
TED expert?
Sep 24th, 2006
Doc says that TED is used to reduce the overhead when you have a lot of IPSEC peers and would not like to specify peers on all.
My question is that how would a router know which router to send the probe to, to setup a IPSEC Tunnel.
Lets say I have a full mess of 100 routers which want to communicate with each other using IPSEC, I use ted and do not define isakmp endpoints, how do the routers know where to send the probe to(which router) to form SA.
NAVIN PARWAL Mon, 09/25/2006 - 07:44
Would appreciate if someone could give a good explaination, there are only 2 routers in the configuration example, what if i had 100? How would peers know whom to form adjencies with.
Tarun
