CUE AA Script
Sep 24th, 2006
Hey All, Looking for a jump start on a script as i'm new to this. If anyone has a similar script that mirrors some of these requirements. The AA is to be set manually everynight for after hours.
Welcome prompt followed by menu options:
Option 0 for Operator which goes directly to operator VM - Option 5 - option 6 (options 5 and 6 are identical trees)
Option 5 emergency
Leave Voice Mail followed by # for save than options
1. view recording
2. confirm/review
3. erase
4. add on
5. erase/new
6. saves and sends PAGE TO ONCALL PERSON
0. operator voice mail ? takes you to Operator, leave VM and exit
*. Exit and return to main
Option 0 to Operator Voice mail
Leave Voice Mail than exit
Thanks in Advance..
Kurtis
Markus Schneider Mon, 09/25/2006 - 06:15
  • Cisco Employee,
The auto attendant scripting doesn't allow you to record any recordings for voicemail and the voicemail script is not customizeable (with the script editor).
