Warning message
DHCP service on AIR-AP1231
Sep 25th, 2006
Hello everyone
I'll be short
please help me to configure Cisco WiAP AIR-AP1231 to give ip address from this range (192.168.1.2-192.168.1.50) to client devices that are connected through radio interface.
How to configure that in cisco IOS ?
Thank you
Overall Rating: 4 (1 ratings)
ethiel Mon, 09/25/2006 - 07:11
  • Gold, 750 points or more
APs are not able to serve DHCP to clients any differently than other IOS devices. To do this, you will need to define the DHCP pool on the AP, then if the AP IP is on a different vlan than the users will be, you need to set up an IP helper address on the router pointing to the IP of the AP.
narius210 Mon, 09/25/2006 - 22:07
Thank you
and if I do not use any VLAN ?
then how should I configure my AP to assign class B private IP addresses on client devices on Dot0 interface ?
Thank you again
ethiel Tue, 09/26/2006 - 07:56
If you're not using VLANs, you just need to give your AP an IP in the range you want to assign IPs from, then define the dhcp pool. For example, if you were trying to use 172.60.0.0/16 You would give the AP an IP (172.16.0.2 for innstance) and do the following config:
!exclude first 2 IPs from DHCP
ip dhcp excluded-address 172.16.0.1 172.16.0.2
ip dhcp pool test
network 172.16.0.0 255.255.0.0
default-router 172.16.0.1
dns-server x.x.x.x
