Warning message
Unable to Load NAM Module - showing PwrDown
Sep 25th, 2006
I have a NAM Module installed in a Cat 6509 and I am unable to bring it online.
The Show Mod command shows that the module is in the PwrDown status.
If I reset the module by reseating it in the chassis I get a logg message saying:
%C6KPWR-SP-4-DISABLED: power to module in slot xx set to off (Module Failed SCP dnld).
Does this mean that the module has a fault or is there a way to recover?
PS - I have tried reloading the whole switch and it makes no difference.
glen.grant Mon, 09/25/2006 - 06:48
  • Purple, 4500 points or more
If this is hybrid did you try the "set module power up " command ?
neiljbooth Mon, 09/25/2006 - 06:50
Hi Glen,
The 6500 is running IOS, do you know if there is an equivalent command?
glen.grant Mon, 09/25/2006 - 07:16
You can try hw-module module X reset . X is your module number . I doubt there is a problem with the nam just sounds like the mod is powered down.
neiljbooth Wed, 09/27/2006 - 01:16
I tried this and it didn't make any difference.
Anybody have any other ideas?
vill_21 Wed, 09/27/2006 - 20:13
Can you verify if there is enough power to support the module? Just a guess.
Vilas
Anonymous (not verified) Thu, 09/28/2006 - 13:40
Anonymous (not verified) Thu, 09/28/2006 - 13:41
Anonymous (not verified) Thu, 09/28/2006 - 13:42
pauvo Thu, 09/28/2006 - 15:05
Check your catos version and check to see the minimal required code to run NAM module. It probably powered down because the SUP did not recognized it.
