Warning message
Active Server Pages error 'ASP 0240'
Sep 25th, 2006
Hi ,
Getting this error message intermittently when trying to login to a Call Manager admin web page. It continues to give out this error message. Then if you leave it alone for a few hours - it seems to clear itself.
The Call Manager version is 3.3(3)
Below is the full error message http page that appears after trying to login (the same everytime I think)
Script Engine Exception
/ccmadmin/default.asp
A ScriptEngine threw expection 'C0000005' in 'IActiveScript::AddNamedItem' from 'CActiveScriptEngine::RequestItems()'.
A ScriptEngine threw expection 'C0000005' in 'IActiveScript::SetScriptSite()' from 'CActiveScriptEngine::Init()'.
gogasca Mon, 09/25/2006 - 11:10
  • Green, 3000 points or more
Please take a look at this FN
It says CCM 3.3(5) but please clear Internet cache to see if it helps, also let us know the MLA version.
http://www.cisco.com/en/US/customer/products/sw/voicesw/ps556/products_field_notice09186a008043b782.shtml
CSCsa80110
Symptom:
MLA enabled. When browsing thru ccmadmin/ccmservice pages, or even at first login, we get the following error msg:
Failed to create ASP object: for _RemoteScripts /rs_logon.asp
Conditions:
Callmanager 3.3.(5), MLA 1.2(4)
Workaround: Clear internet cache or uninstall MLA
//G
gglynn001 Tue, 09/26/2006 - 05:37
Hi gogasca,
Thanks very much - your reply looks spot on. I tried clearing the internet cache, but it made no difference. I will uninstall the MLA application next - how do you do this when the Admin web page is inaccessible ?
Cheers
Ger
