prefix-list vs access-list and these two articles
Answered Question
Sep 25th, 2006
I have read in CCNP curriculum that Cisco says :
" Use prefix lists as an alternative to access lists with many BGP route filtering commands. The advantages of using prefix lists rather than access lists include the following :
1- Significant performance improvement in loading and route lookup of large lists.
2- Support for incremental updates. Filtering by way of extended access lists does not support incremental updates.
3- A more user friendly command-line interface.
4- Greater flexibility ".
But when I read the article below , I could not figure out what does he mean :
" Unlike the IP access-list, which was designed to match traffic, the IP prefix-list was designed specifically with network reachability information in mind ".
Correct Answer by Richard Burts about 10 years 10 months ago
This link is to a good article by Russ White in the Internet Protocol Journal which includes some discussion of control plane and data plane (forwarding plane). I hope that it will help you to understand these concepts.
http://www.cisco.com/web/about/ac123/ac147/archived_issues/ipj_7-1/high_availability_routing.html
Rick
Correct Answer by Harold Ritter about 10 years 10 months ago
What this article means is that the prefix-list would be used at the control plane level rather than the forwarding plane level.
For instance you wouldn't use a prefix-list to filter traffic (forwarding plane) as you do with an ACL. The prefix-list is mainly used for route filtering (control plane).
Hope this helps,
Overall Rating: 4.3 (3 ratings)
Correct Answer
Harold Ritter Mon, 09/25/2006 - 23:14
  • Cisco Employee,
Hope this helps,
zillah2004 Tue, 09/26/2006 - 07:55
((control plane level rather than the forwarding plane level)).
Thanks hritter, could you kindly explain it with more details, because I did not get what is the exact difference, between the control level and the forwarding level ?
Correct Answer
Richard Burts Tue, 09/26/2006 - 08:49
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Rick
