Warning message
IOS Router Cisco VPN Client 4.8
Sep 26th, 2006
I recieve always an error message(%CRYPTO-6-IKMP_MODE_FAILURE: Processing of Aggressive mode failed with peer at 213.180.170.230) when I try to connect with the VPN Client.
See the configuration on the Router:
Router#sh run
Building configuration...
Current configuration : 2164 bytes
version 12.4
service password-encryption
hostname Router
boot-start-marker
boot-end-marker
enable secret xxx
aaa new-model
aaa authentication login default local
aaa authentication login VPN_USER local
aaa session-id common
resource policy
ip cef
username delec password xxx
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp client configuration group VPN_HEIDELBERG
key smart700
dns 192.168.10.100
domain santhera.intra
pool VPN_POOL
crypto ipsec transform-set 3DES esp-aes 256 esp-sha-hmac
crypto dynamic-map VPN_DYNAMIC 10
set transform-set 3DES
reverse-route
crypto map CLIENTMAP client authentication list VPN_USER
crypto map CLIENTMAP client configuration address respond
crypto map CLIENTMAP 10 ipsec-isakmp dynamic VPN_DYNAMIC
interface FastEthernet0/0
description $ETH-LAN$$FW_OUTSIDE$
ip address 192.168.32.33 255.255.255.0
ip nat outside
no ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
description $ETH-LAN$$FW_INSIDE$
ip address 192.168.40.1 255.255.255.0
ip nat inside
duplex auto
speed auto
ip local pool VPN_POOL 10.199.2.0 10.199.2.50
ip route 0.0.0.0 0.0.0.0 192.168.32.32
ip http server
no ip http secure-server
ip nat inside source list 100 interface FastEthernet0/0 overload
access-list 100 remark SDM_ACL Category=2
access-list 100 deny ip 192.168.40.0 0.0.0.255 10.199.1.0 0.0.0.255
access-list 100 deny ip 192.168.40.0 0.0.0.255 192.168.30.0 0.0.0.255
access-list 100 deny ip 192.168.40.0 0.0.0.255 192.168.20.0 0.0.0.255
access-list 100 deny ip 192.168.40.0 0.0.0.255 192.168.10.0 0.0.0.255
access-list 100 deny ip 192.168.40.0 0.0.0.255 10.199.2.0 0.0.0.255 log
access-list 100 permit ip 192.168.40.0 0.0.0.255 any log
control-plane
line con 0
line aux 0
line vty 0 4
password xxx
scheduler allocate 20000 1000
webvpn context Default_context
ssl authenticate verify all
no inservice
end
I'm running IOS 12.4(6)T3 AdvSecurity
So what's wrong?
Peter
m-haddad Tue, 09/26/2006 - 07:31
  • Silver, 250 points or more
Missing some configuration
reverse-route
Where is the ACL to match. You need an ACL to match traffic and encrypt it. THe acl should include traffic from your LAN to the remote VPN Pool Subnet.
It should look like that:
reverse-route
acl 104
access-list 104 remark Remote VPN Clients
access-list 104 permit ip 10.199.2.0 0.0.0.255 192.168.32.0 0.0.0.255
Another thing:
reverse-route
set isakmp-profile VPN_HEIDELBERG
You were missing the last line,
Please let me know if it works and rate if I could help,
m-haddad Tue, 09/26/2006 - 07:32
By the way you need a route map with the nat statement so that you don't NAT traffic between your LAN and the remote VPN client subnet. Therefore, the route-map should deny all traffic from your LAN to remote VPN client subnet and permit anything else.
m-haddad Tue, 09/26/2006 - 07:34
Sorry some mistakes:
reverse-route
reverse-route
acl 104
access-list 104 permit ip 10.199.2.0 0.0.0.255 192.168.40.0 0.0.0.255
Another thing:
reverse-route
No need for the route-map you already deny it using the ACL for the NAT.
pwenger Tue, 09/26/2006 - 21:38
I found the mistake I made.
I forgot some aaa statements.
Altough I tought, that there is no need for authorization you have to configure it.
Thanks anyway for all replies
Peter
