Warning message
AIM Unity Express recovery
Sep 26th, 2006
I had several electrical problem for about an hour powering down and up the router for about 4 or 6 times, after that the router restart to work as normal but the AIM Unity Express did not start as normal. I have a message that is trying to recover from error and that is not available.
I reload, reset, shutdown and I can not log in, I can not even ping to the CUE, when I try to shutdown the module it says that the shutdown is not complete and when I start a session it stays there doing nothing.
The worst of this is that I think the data is missing or lost, how can I recover to upload the system to the compactflash memory card??
Very urgent, please need help.
Thanks.
Juan Carlos Ari... Tue, 09/26/2006 - 13:28
The last info I got, is that the CompactFlash is damage, I receive the message:
Not a cisco supported CF. Please use cisco supported CF and reinstall the software.
System Halted.
Does this CompactFlash has a solution erasing it and uploading again the software?? Do I have to use erase flash: (ClassB) or format flash: (ClassC)??
Is there a way to do it in the same router??
Thanks, please any help.
