ASA 7.2 H323 Inspection
Sep 26th, 2006
  • Blue, 1500 points or more
I am trying to configure H323 inspection on an ASA5520 version 7.2(1). The calls connect, but the embedded IP is not being changed, so there is no inbound audio/video. If I configure the video endpoint to embed the public address (behind FW setting, which breaks internal calls)the call is fine.
The config for this is very simple, but perhaps I am missing something.
<i>policy-map global_policy
class inspection_default
inspect h323 h225
inspect h323 ras
an-j2-asa5520-1# sh h225
Total: 2
1 Concurrent Call(s) for
Local: 10.140.0.100/3235 Foreign: VideoTestSite/1720
Local: 10.140.0.100/3233 Foreign: VideoTestSite/1720
0 CRV: 22908 Local: 10.140.0.100/3233 51 Foreign: -1644032441 184.6.0.0/138 0
1 CRV: 22909 Local: 10.140.0.100/3235 51 Foreign: -1644032441 184.6.0.0/138 1</i>
dgahm Tue, 09/26/2006 - 16:40
Guess I should have done the bug search first:
CSCse86982
Running 7.2(1) video conferences fail through firewall. No audio or video will pass. inspect h323 enabled, but not natting embedded ip addresses
The workaround is to downgrade to 7.0(5). Hopefully there will be a quick fix for this one.
