Warning message
Voice T1 Errors
Sep 26th, 2006
I have a new router with a T1 being split between voice and data. Currently only the ds0 group for voice is setup. On inbound calls I get the following from my cell to the offic ein question
*Sep 27 05:02:39.979: //-1/3C1200DA8133/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x465B1A68; count=1
*Sep 27 05:02:39.983: //-1/3C1200DA8133/RXRULE/regxrule_stack_push_RegXruleNumInfo: stack=0x465B1A68; count=0
*Sep 27 05:02:39.983: //-1/3C1200DA8133/RXRULE/regxrule_stack_push_RegXruleNumInfo: stack=0x465B1A68; count=1
*Sep 27 05:02:39.983: //-1/3C1200DA8133/RXRULE/regxrule_dp_translate: No profile found in peer 200 for outgoing direction
*Sep 27 05:02:39.983: //-1/3C1200DA8133/RXRULE/regxrule_dp_translate: calling_number=911 calling_octet=0x0
called_number=6242 called_octet=0x0
redirect_number= redirect_type=0 redirect_plan=0 redirect_PI=0 redirect_SI=0
*Sep 27 05:02:39.983: //-1/3C1200DA8133/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x465B1A68; count=2
*Sep 27 05:02:39.987: //-1/3C1200DA8133/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x465B1A68; count=2
*Sep 27 05:02:39.987: //-1/3C1200DA8133/RXRULE/regxrule_stack_push_RegXruleNumInfo: stack=0x465B1A68; count=1
*Sep 27 05:02:58.339: //-1/3C1200DA8133/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x465B1A68; count=2
Fridley_Core#
*Sep 27 05:03:07.739: %SYS-5-CONFIG_I:
The dial-peer 200 looks like this...
dial-peer voice 200 voip
destination-pattern 6...
progress_ind setup enable 3
session target ipv4:10.249.32.2
dtmf-relay h245-alphanumeric
codec g711ulaw
fax rate disable
ip qos dscp cs5 media
no vad
I have been at this install for way to long and am sure at this point am missing something straight forward. Any help is greatly appreciated!
