Warning message
Recovering from Failed Upgrade
Answered Question
Sep 27th, 2006
AP Model: AIR-AP1220B-E-K9
We recently tried to upgrade this from VXWorks 12.03T to IOS, but something went wrong. We now get the following prompt only:
c -- Copy file
f -- File dir
l -- downLoad file into DRAM
u -- Upload file
p -- xfer Protocol
n -- coNsole
r -- Run
s -- System info.
I've therefore redownloaded the 12.03T VXworks image file and uploaded it via the console cable using 1K-Xmodem and baud rate 115200. The file appears to upload successfully, so I click r for run, but keep getting the following output:
a -- EnterpriseAP Sys 12.03
a
Inflating "EnterpriseAP Sys 12.03"...
** Error in Compression Codes
*** Bad CRC in File DRAM :00008720
Memory Bank total used left
DRAM 16742624 0 16742624
Config 524288 0 524288
FLASH 7602176 0 7602176
Memory Bank:File address size encoding type flags
*** Decode Error 00000001
I've tried this a few times now and redownloaded the image incase it was corrupt but with the same problem.
Can anyone help me? Cheers!
Correct Answer by Rob Huffman about 10 years 10 months ago
Hi Paul,
Have a look at the following;
Verify that the connection settings in the terminal application are 9600-8-None-1 and NO flow control (not hardware or software).
From this doc;
Recover from a Failure
http://www.cisco.com/en/US/products/hw/wireless/ps430/products_tech_note09186a008019fea0.shtml#topic2
Part of this comprhensive doc;
Upgrade Cisco Aironet AP1200 to IOS
Hope this helps!
Rob
Please remember to rate helpful posts.....
Overall Rating: 5 (1 ratings)
Correct Answer
Rob Huffman Wed, 09/27/2006 - 08:56
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Paul,
From this doc;
Hope this helps!
Rob
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
