Warning message
Microsoft Message queuing, Unity 4.05 with CCM 4.2 and Exchange 2003 ??
Sep 27th, 2006
Having periodic problems with Unity 4.05 server and Microsoft Message Queueing. The last event viewer message that started it all was:
Event Type: Error
Event Source: CiscoUnity_DSGC
Event Category: Error
Event ID: 1049
Date: 9/26/2006
Time: 2:52:34 PM
User: N/A
Computer: NFUNITY
Description:
The Cisco Unity service that monitors the global catalog (AvDSGlobalCatalog) failed to synchronize data for an object in the global catalog with the corresponding data for the object in the SQL Server/MSDE database on the Cisco Unity server. Unity will not be able to synchronize all changes for this object until this is resolved. However, other objects will continue to be synchronized.
Type: AVOBJECTTYPE_SERVER
Reason: 0x80044A08 0x80044A08: <unknown>
Restarted Unity but no change. Then did a net stop msmq and the service would not stop. Rebooted Unity server and then Microsoft Message Queueing would not START and neither would alot of Unity services. Removed Microsoft Message Queing rebooted server, reinstalled MSMQ, rebooted server then all of Unity started fine. Problem is this is the second time in two months that I had to remove MSMQ to fix UNITY?? Can Anyone tell me what's going on and why MSMQ seems to be getting "corrupted"
Thanks in advance,
Tony
