09-27-2006 08:48 PM - edited 03-03-2019 05:16 AM
I have a problem here when i connect this module NM-2CE1T1-PRI to a C3640 Model(C3640-JK9S-M) , IOS ver 12.1,
I got this error:
Unsupported I/O Controller (type 926) in I/
O Bay. The I/O Controller network interfaces will be unavailable.
WHat is this due to ?
thanks!
Solved! Go to Solution.
10-03-2006 03:41 PM
The Cisco E1/T1 ISDN PRI network modules are supported in the Cisco 2610-51XM, 2800, 2691, 3660, 3700, and 3800 routers. Refer http://www.cisco.com/en/US/products/hw/modules/ps2797/products_data_sheet09186a0080189f95.html for more information.
10-03-2006 03:41 PM
10-03-2006 09:57 PM
You have been replied for this same query on 27th.
For more details on the module chk below link
Rahul
10-03-2006 10:03 PM
You need atleast 12.3 or 12.3T for this module to be supported on 3600 router.
HTH,
-amit singh
10-04-2006 02:47 AM
What version of IOS you have ,I think the software you have not compatible with hardware
10-04-2006 07:22 AM
Hi, I ran into this exact problem about 6 months ago. You will need the older NM, which is NM-2CT1-CSU, or the 1 port NM to work in the 3640..These are end of sale, so you will have to find one refurbished.
