Warning message
2610 router booting prob
Sep 28th, 2006
Hi All..
i am gettign folowing message while i boot 2610 router,
device does not contain a valid magic number
boot: cannot open "flash:"
boot: cannot determine first file name on device "flash:"
System Bootstrap, Version 11.3(2)XA4, RELEASE SOFTWARE (fc1)
Copyright (c) 1999 by cisco Systems, Inc.
TAC:Home:SW:IOS:Specials for info
C2600 platform with 32768 Kbytes of main memory
I try with tftpdnld command from rommon mode but its not working it says Ready to Download and get timed out..
Any body knows reply....
Dhaval Tandel
mmorris11 Thu, 09/28/2006 - 09:39
  • Silver, 250 points or more
WEre you able to ping the tftp server before trying to download in rommon?
dhavaltandel Fri, 09/29/2006 - 00:21
Hello
In rommon mode if i setup the ip address and all than it takes it properly but if i ping from tftp to router ip address configured than it wont ping.
i found my flash is empty or currepted...and the tftp is the way to load ios i have from tftp server....
i follow
-configure ip add, subnet mask, tftp server add. from rommon mode.
-but still i cant ping router ip address i configured.
-tftp is working fine i tried by ping from another workstation in my network.
anybody has solution do reply..
thanks
dhaval tandel
ariazk@gmail.com Fri, 09/29/2006 - 03:23
what router model you are using, if you can try reseting the flash or replaced the flash.
regards
