WCS Busiest Client Report Problem
Sep 28th, 2006
  • Bronze, 100 points or more
We are using Wism 4.0.155.5 and WCS 4.0.81.0. Everytime I run "busiest client report" on WCS, I get some clients with throughput more than 70Mbps and utilization more than 600%!!! It is very weird. Anyone see this as well? Thanks.
bwalchez Wed, 10/04/2006 - 06:47
The throughput can be upto 512mbps depending upon the module you are using. This may also depends on the encryption done on the data sent.
ethiel Wed, 10/04/2006 - 21:22
  • Gold, 750 points or more
zhenningx:
I see it too. It definitely appears to be a bug, but I will do some checking. Mine show upwards of 2000% and most of my top 25 show an almost identical tx/tx amount of 4gb.
If I make any headway with TAC, I'll let you know.
