09-30-2006 01:08 AM - edited 03-10-2019 02:46 PM
DearPros,
After i installaed the CSACS 3.3 on windows 2003 server,when i access it via web browser i am getting the following message
USERNAME :admin
PASSWORD : admin
Login failed...try again
I just login after the fresh installation.what is the defaukt username and password to use.
swamy
10-01-2006 03:47 PM
hi
normaly the username and the password are correct, make sure the interface is up on your server or just go the server itself and try http://127.0.0.1:2002 if does not work verify your java, and your browser .
10-02-2006 06:14 AM
Hi Swamy,
There is no default username and password associated with ACS software, as you are trying to access the server remotely you would first have to create an admin account on ACS server.
Logon to the server itself locally as ACS install Java runtime on it from www.java.com as 2003 does not have java pre-installed on it.Next open IE and goto http://127.0.0.1:2002
On the ACS GUI interface click on Administration Control-->Add administrator and create a admin account there make sure you click the Grant All button.
You can now login to ACS using this admin account.
I hope this helps.
Gagan
