port channel as a layer 3 interface
Oct 1st, 2006
I have just inherited a very complex network and noticed in the config, for a cat-6513 with layer 3, the following:
interface Port-channel34
ip address 10.20.4.10 255.255.255.252
What would be a rationale for making a port-channel a layer 3 port?
thanks.
vladrac-ccna Sun, 10/01/2006 - 12:47
  • Silver, 250 points or more
Have you ever configured a multilink ppp interface?
Vlad
gpulos Sun, 10/01/2006 - 13:16
  • Blue, 1500 points or more
in the case of a portChannel as an L3 entity, it allows for the added capacity/redundancy of the link as well as provides the layer 3 topology either wanted or in some instances, required, such as when you need to make a multilink connection to a router from your switch.
or perhaps you have a routed core infrastructure created in your L3 environment and you wish to increase the capacity of the links between devices without using VTP/trunking.
axfalk Sun, 10/01/2006 - 18:14
Thanks for your response. Would it be possible to point me to a doc discussing this feature? Thanks again
