Phones pull IP from Data DHCP
Answered Question
Oct 2nd, 2006
Hello all -
I'm having a problem that seems to be getting worse. I have 350 or so 7910/40/60 phones running on CCM 3.2 (1 pub, 1 sub, 1 unity) in a small office environment. When phones are restarted for whatever reason (switch matintenence, etc), some of the phones register with the DHCP server on the data VLAN vs. the Voice DHCP scope located on publisher. This prevents the phone from contacting the correct TFTP server and registering with the call managers.
I have seperate voice and data VLAN's configured and a DHCP server on each for IP's. No helper addresses are configured on the voice network, so I can't see why the phones are jumping over the the data vlan and dhcp server.
Any ideas?
Jad
Correct Answer by Patrick Cloutier about 10 years 10 months ago
I had the same issue as well. To resolve it, I had to put the switchport access vlan on the phone vlan, let the phone boot once and upgrade its firmware. I was then able to put the access vlan back to the data vlan.
Let me know if this works for you.
Correct Answer by jasonhauck about 10 years 10 months ago
We had the same issue, it was a problem with the firmware load for the phone. Either put option 150 on the data VLAN or upgrade the phone load. Hope it helps (assuming it's the same issue).
Overall Rating: 4 (2 ratings)
Aaron Harrison Mon, 10/02/2006 - 06:56
  • Community Spotlight Award,
    Member's Choice, May 2015
What kind of switches are you running?
Can you post the config of a switch that exhibits this problem?
Aaron
jelzein Mon, 10/02/2006 - 08:38
Aaron - thanks for the quick response. Unfortunately i can't post the full config due to our security regulations. I'm using various switch models on each floor, but the most recent problem involves a 3560:
(C3560-I9-M), Version 12.1(19)EA1d, RELEASE SOFTWARE (fc1).
Let me know if you're looking for something specific.
Jad
Correct Answer
jasonhauck Wed, 10/04/2006 - 10:10
Correct Answer
Patrick Cloutier Thu, 10/05/2006 - 10:06
jelzein Thu, 10/05/2006 - 13:03
Thanks guys - i updated the loads for all 7940's and 7960's to P00308000200, rebooted, and all went well.
