10-03-2006 06:15 AM
I have the some number in the "number of devices" field for the Partially Sucessful state in the RME/Config Mgmt Archive Mgmt. But configurations from these devices are fetched in RME database. Can I clear this statistics in the Partially Successful state?
Config Archival Status No. of Devices
Successful 1
Failed 0
Partially Successful 1
Total 2
Thank you
10-03-2006 02:20 PM
There is a database query that can be run to do this, but it is not recommended. Given the small number of devices, you might consider reinitializing the entire RME database. Assuming you are then on the latest version of LMS (LMS 2.6), this problem should not reoccur.
To reinitialize the RME database, use the following command:
NMSROOT/bin/perl NMSROOT/bin/dbRestoreOrig.pl dsn=rmeng dmprefix=RME
10-04-2006 07:15 AM
Thank you. I try to update LMS to version 2.6.
Roman
