Warning message
VT Advantage v1.1 unable uninstall or update "Advantage.msi"
Oct 4th, 2006
I?m trying to either uninstall or upgrade VT Advantage on 2 PC's however both show the following message when I try "Windows Installer. The feature you are trying to use is on a network resource this is unavailable. Click OK to try again, or enter an alternate path to a folder containing the installation package 'Cisco VT Advantage.msi'"
This file is not located on my PC and I can't find it located within the original software 1.1 download.
Does anyone know how to deal with this issue so that I can install v2?
Chris
ccpagel Thu, 10/12/2006 - 02:48
Thanks for the Bug ID. This pointed me to a PDF but there was no information relating to my specific problem.
During an attempt to uninstall or a install I still get asked for the CiscoUnifiedVideoAdvantageSetup.msi file but this does not exist. Its file is part of 2.0.2 but if I point the install/uninstall app to this file it says its not the correct version.
Anyone any other idea's?
Chris
