10-05-2006 02:46 PM - edited 03-09-2019 04:26 PM
Our VPN 3015 concentrator connects to outside with its own router tru T1 serial interface. On inside it conects to the same backbone as PIX-525 firewall. When remote users connect to VPN, they cannot access any servers in DMZ. What setting should I change on concentrator or on PIX to get it fixed? I would appreciate any tips and advises.
10-05-2006 07:27 PM
You need to do a couple of things on the concentrator..
1. Make sure you added the DMZ subnet to the Network List for your split tunneling.
2. Add a route on the Concentrator that sends all traffic for the DMZ subnet to the appropriate routing device.
*** Please rate if this helps in any way****
Cheers!
10-06-2006 01:11 PM
Thank you. It works great!
