Warning message
Difference between LAN BAse Image and Enhanced Image
Oct 6th, 2006
Can you tell me the difference between switches with LAN Base Image and Switches with Enhabced Image. I want to run HSRP and OSPF on two switches. Can I use LAN Base Image with this or is switches with Enhanced Image.
Many Thanks
Overall Rating: 5 (2 ratings)
mmorris11 Fri, 10/06/2006 - 08:08
  • Silver, 250 points or more
What series of switch are we talking about?
mmorris11 Fri, 10/06/2006 - 08:58
These are layer two switches and as such will not support these L3 routing features. You will have to step up to at least a 3560 to do this.
