how to redistribute ibgp route to igp protocol.
Oct 7th, 2006
ibgp CAN'T inject route in eigrp or ospf,how can do it.think's
router eigrp 100
log-adjacency-changes
redistribute bgp 1 metric 100 1 255 1 1500
network 154.100.1.0 0.0.0.255
network 154.255.255.0 0.0.0.255
no auto-summary
router bgp 1
no synchronization
bgp log-neighbor-changes
neighbor 154.2.1.252 remote-as 1
neighbor 154.2.1.252 next-hop-self
no auto-summary
Richard Burts Sat, 10/07/2006 - 08:53
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
rusong
From the command reference:
bgp redistribute-internal
To allow the redistribution of iBGP routes into an interior gateway protocol such as IS-IS or OSPF, use the bgp redistribute-internal command in router configuration mode. To remove the bgp redistribute-internal command from the configuration file and restore the system to its default condition where the software does not allow the redistribution of iBGP routes into Interior Gateway Protocols (IGPs), use the no form of this command.
Rick
Edison Ortiz Sun, 10/08/2006 - 06:46
  • Hall of Fame,
    Founding Member
Rusong,
The command should be under the BGP process, not the EIGRP process. Perhaps that's the reason you are unable to enter such command in your config.
_____
HTH,
