Warning message
SRST External Calling Number Mask
Oct 8th, 2006
Is there a way to mask all outgoing call with the main number on a PRI with a DID block in SRST mode. example Phone 1's external phone number mask is Area code + 7 digit extension say 123 123 1001, extension 2 is 123 123 1002 so on. Main number of business is 123 123 1000, what would be the command/syntax to change the external phone number mask for all calls outbound in SRST mode to main number instead of individual DIDs.
Overall Rating: 4 (1 ratings)
thisisshanky Sun, 10/08/2006 - 20:55
  • Purple, 4500 points or more
Assuming you have dialplan pattern set, You can setup a translation rule on all outgoing dial-peers.
voice translation-rule 1
rule 1 /1231231.../ /1231231000/
voice translation-profile 1
translate calling 1
dial-peer voice 1 pots
destination-pattern 9T
port 1/0:23
translation-profile outgoing 1
sankar
PS: please remember to rate posts!
vrana@inetx Thu, 10/12/2006 - 07:08
That worked! I was under the impression that there would be commands under the fall-back section, not realizing that standard translation would do the trick. Thx.
