sundar.palaniappan Mon, 10/09/2006 - 14:04
The command to check the uptime is show version. The uptime can be found in the middle part of the output and it will look something like the below output. Moreover, if the router has an authoritative clock set, either via NTP or manual 'clock set' command, it will display the date/time when it was rebooted.
R2 uptime is 1 week, 2 hours, 12 minutes
System returned to ROM by reload
System restarted at 15:44:41 UTC Mon Oct 2 2006
System image file is "flash:c3640-js-mz.124-7.bin"
Sundar
gpulos Tue, 10/10/2006 - 10:45
use the 'show version' command and view the output for the "uptime".
Alessio Andreoli Mon, 07/23/2012 - 07:32
a quick one more:
sh ver | s uptime ! if you have a relatively recent ios "s" will work otherwise use "inc" after pipe
Alessio
singhaam007 Thu, 09/20/2012 - 02:16
if u only want to see uptime then use
sh ver | inc upt
Please do rate if the given information helps
thanks
Anand G Thu, 12/13/2012 - 03:07
The easiest way is,
show ver | i uptime
Anand G
