Warning message
BGP Datagram size
Answered Question
Oct 9th, 2006
Dear all,
on one of my router(MPLS Service) the BGP datagram size shows as
Datagrams (max data segment is 516 bytes)
and on another router(ISP Service) it shows
Datagrams (max data segment is 536 bytes):
Can anybody tell me the reason of such difference
Mahesh
Correct Answer by Harold Ritter about 10 years 10 months ago
The mtu of 516 is most likely due to the fact that you use MD5 authentication on this session. MD5 authentication adds 20 bytes of overhead in the TCP header, hence the MSS being reduced by 20 bytes.
Hope this helps,
Overall Rating: 4.5 (4 ratings)
royalblues Tue, 10/10/2006 - 06:02
  • Green, 3000 points or more
536 is the default MSS (max segment size) for a TCP connection which is Very small considering the amount of data we transfer.
This can cause delays in BGP convergence.
Enable path MTU discovery and clear the BGP session
ip tcp path-mtu-discovery
clear ip BGP *
check the size now by
show ip bgp neighbor | include max data segment
http://www.cisco.com/en/US/products/ps6922/products_feature_guide09186a0080666002.html
Narayan
mamta.gohil Wed, 10/11/2006 - 01:57
I accept ,
But my basic question is on one of my router it shows 516 and another router it shows 536. why it is so?
i will enable mtu discovery once i take approval from customers..
so please provide me details of why it is 516 if document tells that default is 536
regards!!
royalblues Wed, 10/11/2006 - 02:25
Mahesh,
Have you specified any MTU vlaue on any interface?
Narayan
mamta.gohil Wed, 10/11/2006 - 03:01
Dear Narayan,
I have not specified any MTU on interface
Regards!!
Correct Answer
Harold Ritter Wed, 10/11/2006 - 04:45
  • Cisco Employee,
Hope this helps,
mamta.gohil Wed, 10/11/2006 - 04:58
Thanks hritter and narayan for your extended support.
Regards!!
Mahesh
royalblues Wed, 10/11/2006 - 20:18
Harold
Thanks for the information. Never thought this could be the reason
Narayan
