dpopli Tue, 10/10/2006 - 03:44
It will not do IP processing. However if you want IP processing to be done on serial interface without using IP address use IP unnumbered command
The_guroo_2 Tue, 10/10/2006 - 05:04
if u dont put petrol in your car what will happen it will not run so its simple the router will not be able to route or communicate.......but it can be possible still not putting ip address but can make it work its with ip unnumbered command.....
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_tech_note09186a0080094e8d.shtml
its a v goo dlink for understanding it cheers and rate all post plz
