Corporate Directory as a Softkey instead
Answered Question
Oct 10th, 2006
Is there a way or ideas on moving the Corporate Directory to the Softkey, make it a one touch button to get to the Corporate Directory? Right now, as standard, users press the Directory button, then they choose the Corporate Directory option. I have Callmanager 4.1(3)sr3c.
Correct Answer by gogasca about 10 years 10 months ago
You can configure instead of a Softkey a Phone Button, (Where Speed Dials and DNs are configured)
Under CCMAdmin | Device | Phone Button Template | Customized one | Select Service URL under one of the buttons.
Assign that Phone Button template to the phones.
Create a new IP Phone Service | Called it Directory, use IP Phone Directories URL
(http://W.X.Y.Z/CCMCIP/xmldirectoryinput.asp)
Subscribe the IP Phone to the Directory service.
Then Add/Update Service URL Buttons in the IP Phone, and you are done.
Let me know if this is what u r looking for.
Overall Rating: 5 (2 ratings)
Correct Answer
gogasca Tue, 10/10/2006 - 16:27
  • Green, 3000 points or more
Tommer Catlin Wed, 10/11/2006 - 10:21
But you can't configure a softkey off the bottom 4 for this correct? In the On hook state, you only get the standard options and service URL is not one of them.
