Warning message
CRS 4.0(4) with VXML, failing tor ecognize DTMF with Nuance
Oct 12th, 2006
I'm trying to deploy a VXML application with CRS 4.0(4) using VXML, and when I get to a point where dtmf have to be recognized, I get a no-input-timeout.
Attached is a MIVR log with just the MRCP-ASR Lines.
It's not too clear what is going on there. On the Nuance side, it's like nothing is happening. Could there be something wrong with my configuration?
If I try to detect dtmf from a CRS script application, it seems to work
the difference in the log between my vxml application and the crs script is that the vxml application does a
Entering injectDTMF(2)
Exiting injectDTMF()
while the CRS script does
processDTMFInterpretation(): Tag value for digit: 1 is: extn
thanks
a-vazquez Wed, 10/18/2006 - 15:23
  • Silver, 250 points or more
Check if you have more than one NIC is the server and ensure that the cable is disconnected from the NIC when the server boots.
aboisseau Thu, 10/19/2006 - 05:10
It was in fact the Dual NIC problem, it solved it, thanks.
Now we still have it intermittently, but it seems to be on the Nuance side of things, since the dtmf digits are getting to the switch
