DTMF Digits passing the Voice Gateway
kolkatagtc
iam using Cisco 3825 router where E1 circuits are connected. Need to check the DTMF digits passing when i am trying to connect to an IVR number and the options digits pressed.
How can I get that.
Help required.
Thanks in Advance.
gogasca
Level 10
Level 10
Which VOIP protocol are you using?
If using MGCP check:
debug mgcp packet and look for NOTIFY messages. Check
mgcp dtmf-relay voip codec all mode out-of-band command is configured.
If H225 check dtmf-relay alphanumeric under VOIP dial-peers.
For checking debugs run debug h245 asn1
For TDM run:
debug voip vtsp tone
