Warning message
Pound sign (#) in dial-peer
Oct 13th, 2006
I?ve a problem with a destination.It?s *31#44442222.
The problem is the pound sign. How can I do to make a call to this destination and the call was ok ?
I tried to do the following dial-peer but something was wrong.
dial-peer voice 1 pots
description Llamadas a servicios suplementarios
destination-pattern *31#44442222
clid override rdnis
port 1/0:15
forward-digits all
Thank
MattNicholls_2 Wed, 10/18/2006 - 15:13
Are you using Express or full version?
If you are using Express I haven't worked with that application yet and hopefully someone else can chime in.
If full version and I am using CCM4.1.3sr3a so there might be some differences if your version is different. I have never seen the 31# used for use with POTS. I have seen the pound sign used to signal that there are no more digits expected to be entered. If the digits are only being used to get out of your voip system the settings in the Route List Detail (Route Plan -> Roue/Hunt -> Route List). Choose the PRI, that allows you to choose the details on the left then under the section titled Called Party Transformations, this lets you choose which digits are discarded.
The pound sign is not typically used in regular expressions and as far as the dial-peer config is concerened it isn't listed as an available symbol on the page linked below.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios121/121newft/121t/121t1/dt0390s7.htm
hth
If I am way off base please let me know.
MattNicholls_2 Wed, 10/18/2006 - 15:52
well after reading the document a little more it does show the tech prefix using a pound sign.
you may want to explore that document further.
