Warning message
additional DID plan
Oct 15th, 2006
my service provider added me additional phone numbers to my E1 line (DID).
but they begin with different digits.
My fiest number plan is: 2232195.., SP added me 10 phone nmbers beginig with 2234674.., ho wshould I configure CME to handle it?
Like you can see, some internal numbers starts with 5.. and some with 4.., when calling internaly it is not a problem.
When I have added:
dialplan-pattern 2 2234674.. extension-length 3 extension-pattern 4..
CME stopped to work with my first dialplan-pattern which is:
dialplan-pattern 1 2232195.. extension-length 3 extension-pattern 5..
any suggestions?
regards
Slawek
Overall Rating: 3 (1 ratings)
Chris Deren Sun, 10/15/2006 - 12:20
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Can you please post your configuration?
Chris
slawek_jg Mon, 10/16/2006 - 07:40
my config looks like:
voip-incoming translation-rule called 1
translation-rule 1
Rule 1 ^2232195 5
Rule 2 ^2234674 4
translation-rule 11
Rule 1 ^0 00
dial-peer voice 10 pots
incoming called-number 223319...
direct-inward-dial
dial-peer voice 100 pots
destination-pattern 0T
translate-outgoing called 11
port 0/0/0:15
telephony-service
load 7912 P00307020200
max-ephones 48
max-dn 96
ip source-address 10.48.4.1 port 2000
system message CISCO powered by InfoLAN
url services http://10.48.4.2/voiceview/common/login.do
url authentication http://10.48.4.2/voiceview/authentication/authenticate.do
time-format 24
date-format dd-mm-yy
create cnf-files version-stamp 7960 Oct 14 2006 16:45:08
voicemail 2369
max-conferences 8 gain -6
dn-webedit
time-webedit
what to do to make work both dial-plans?
regards
Slawek
Chris Deren Mon, 10/16/2006 - 08:03
  • Hall of Fame,
Well, you have only one inbound pots dial-peer defined (dial-peer 10), which will only match 223319... numbers, in order to match the 2234674.. numbers as well you have couple of options:
1. change dial-peer 10 to the following
incoming called-number .
direct-inward-dial
port 0/0/0:15
2. Add another dial-peer
incoming called-number 2234674..
direct-inward-dial
port 0/0/0:15
And add the 2 dialplan pattern under telephony-service.
Also, I'm not sure what the translation rule 1 is for, but it's not applied to anything.
HTH,
Chris
slawek_jg Wed, 10/18/2006 - 09:34
I have added another dial-peer
dial-peer voice 11 pots
direct-inward-dial
port 0/0/0:15
in dial-peer voice 10 I have added line:
port 0/0/0:15
then in telephony-service:
After that, my 2nd dialplan is working, 1st is not working :-(
Why?
regards
Slawek
Chris Deren Wed, 10/18/2006 - 12:02
  • Hall of Fame,
What does your "debug isdn q931" show?
What happens if you change the "incoming called number ."
Chris
slawek_jg Thu, 10/19/2006 - 01:21
but when I change to "incoming called-number ." should I also add dialplan-pattern?
Slawek
slawek_jg Thu, 10/19/2006 - 03:47
I have just change (only this) "incoming called-number 2232195.." to "incoming called-number .", now I can dial this numbers (form public), but cannot dial 2234674.. numbers :-(
Do I have to reload CME or sth?
Slawek
Chris Deren Thu, 10/19/2006 - 04:18
  • Hall of Fame,
Can you post your entire config, and "debug isdn q931" for both calls?
Chris Deren Thu, 10/19/2006 - 06:47
  • Hall of Fame,
Slawek,
I looked at your configuration and there are couple of things:
1. The voip-incoming translation-rule 1, is a global translation-rule that will apply to all incoming voip dial-peers, not sure why you need it?
2. I noticed that you have only one ephone-dn, When you perform your testing do you change it back and forth, same with your FXS ports?
Besides the isdn q931 debugs another one to try is "debug voice dialpeer" and "debug voice translation"
Chris
l.mourits Thu, 10/19/2006 - 04:21
  • Silver, 250 points or more
Slawek,
I do not see any voip dialpeers in your config. I have the similar with one of my sites and here is an extract of my config:
dial-peer voice 101 pots
direct-inward-dial
dial-peer voice 102 pots
direct-inward-dial
dial-peer voice 1001 voip
destination-pattern
session protocol sipv2
session target ipv4:
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 1002 voip
destination-pattern
codec g711ulaw
no vad
telephony-service
dialplan-pattern 1 extension-length 4
dialplan-pattern 2 extension-length 4
I also had the second DID range come in on another PRI, which is why I also had to add custom cor lists but in your case this is not needed.
Hope it helps,
Leo
Chris Deren Thu, 10/19/2006 - 04:51
  • Hall of Fame,
You do not need any voip dialpeers if the CME is on the same router as the PRIs.
Chris
l.mourits Thu, 10/19/2006 - 06:13
Chris,
If combined with CUE like Slavek and I do there is a need to create the Voip dialpeers for voice mail to work. You will see this in his config as well:
dial-peer voice 1 voip
translation-profile outgoing 1
destination-pattern 2...
session target ipv4:10.48.4.2
dtmf-relay sip-notify
codec g711ulaw
no vad
All Slawek needs to do IMHO is adding the following:
dial-peer voice 2 voip
destination-pattern 4...
codec g711ulaw
no vad
Leo
Chris Deren Thu, 10/19/2006 - 06:36
  • Hall of Fame,
Leo,
I appologize for not reading your entire post.
I was only concentrating on his issue which is that calls do not get delivered to the phones.
You are correct that you require the dial-peers to re-direct to CUE.
Chris
l.mourits Thu, 10/19/2006 - 06:49
Thanks Chris,
Since one typically would test to see if it works by calling the number and see if it hits voicemail I just had to bring the voip dialpeers to the table (been there, done it, had the same problem :-))
Leo
