AAA server marked as dead
Oct 16th, 2006
We have configured 2 AAA servers for Wireless authentication purposes.
Now everything falls to the backup because the primary is marked as dead :
What are the points to check what is wrong ? The primary server is up and running, perhaps a problem with Radius ?
Oct 16 11:15:49: %DOT11-6-ASSOC: Interface Dot11Radio0, Station PO040003875 000f
.2093.94a0 Associated KEY_MGMT[NONE]AAA/SG/SERVER_SELECT Server (10.2.17.201:164
5,1646) marked dead. Skipping.
a.kiprawih Mon, 10/16/2006 - 03:33
  • Gold, 750 points or more
The problem indicates the primary ACS Server failed to respond to authentication request (radius).
The server might be up & running, and you even ping it without any problem. This has something to do with the radius (or tacacs+) services. Check the radius status from the ACS "Reports & Activity - ACS Service Monitoring", or from the server's event viewer.
Under the ACS Service monitoring, check the latest 'CSMonLog.csv' (or older file) for any CSRadius failed services.
AK
lni1 Mon, 10/16/2006 - 05:27
I found it, It was the proxy distribution table that was configured faulty.
Thanks anyway for your assistance
Lieven
