PIX configuration with multiple NAT statements
Answered Question
Oct 16th, 2006
hi,
I have PIX running version 7.1(2). I use "nat 0" for all outbound traffic to bypass NAT. I have 5 different networks bypassing the PIX NAT. But I would like to apply NAT just for a new network without affecting other traffic. I want this new network to be translated to a specific routable IP.
is this a possible solution? I am trying to aplly NAT on only 10.1.1.0 255.255.255.0 network.
global (OUTSIDE) 1 192.168.1.2
nat (INSIDE) 1 10.1.1.0 255.255.255.0
nat (INSIDE) 0 0.0.0.0 0.0.0.0
Ercan
Correct Answer by a.kiprawih about 10 years 10 months ago
It should work. I assumed the 192.168.1.2 is an IP belongs to the same range of outside interface/Public IP (assigned by ISP).
Your 'nat (inside) 1' and 'global (outside) 1' pair will correctly allow hosts on 10.1.1.0/24 to go out using the single IP, and skip the NAT 0.
AK
Overall Rating: 5 (1 ratings)
Correct Answer
a.kiprawih Mon, 10/16/2006 - 08:05
  • Gold, 750 points or more
AK
dpopli Tue, 10/17/2006 - 01:05
Please check for outside address 192.168.1.2
It is a private address and can not be provided by ISP
ercanelibol Tue, 10/17/2006 - 04:20
thanks for the reply, I know it is a private address, I am just giving an config example. let me rewrite it again for you then. Do you think it is going to work?
global (OUTSIDE) 1 122.18.1.2
thanks
Ercan
