Warning message
ACL in RSM
Oct 17th, 2006
Hi, I work with Catalyst 4006 + RSM. My interfaces are configured as trunks, and subinterfaces for each vlan: gigabit 3.1, 3.2, 4.1, 4.2, etc. I have an ACL applied on the inbound line vty and it is work ok. But for a subinterface don't work.
IOS (tm) L3 Switch/Router Software (CAT4232-IN-M), Version 12.0(10)W5(18f)
ROM: System Bootstrap, Version 12.0(7)W5(15b) RELEASE SOFTWARE
ROM: L3 Switch/Router Software (CAT4232-IN-M), Version 12.0(25)W5(27) RELEASE SOFTWARE
Router uptime is 19 weeks, 1 day, 19 hours, 31 minutes
System restarted by power-on at 17:00:07 edt3 Sun Jun 4 2006
Running default software
cisco Cat4232L3 (R5000) processor with 57344K/8192K bytes of memory.
R5000 processor, Implementation 35, Revision 2.1
Last reset from power-on
1 FastEthernet/IEEE 802.3 interface(s)
4 Gigabit Ethernet/IEEE 802.3z interface(s)
123K bytes of non-volatile configuration memory.
16384K bytes of Flash internal SIMM (Sector size 256K).
Configuration register is 0x2
Anybody can help me?
Thks,
Paulo
s.jankowski Fri, 10/20/2006 - 13:50
  • Bronze, 100 points or more
I think the ACL type is mismatching in the subinterface
royalblues Fri, 10/20/2006 - 19:37
  • Green, 3000 points or more
Can you share your configurations
Narayan
paulo.s Mon, 10/23/2006 - 04:54
Hi Narayan,
I configured VLAN trunking on the two internal Gigabit Ethernet interfaces, from the supervisor engine as well as from the layer 3 Services module.
interface GigabitEthernet3.102
description Vlan Acesso Rede Adm SUN
encapsulation dot1Q 102
ip access-group 101 in
ip address 10.0.30.1 255.255.255.0
no ip redirects
no ip directed-broadcast
no cdp enable
access-list 101 permit ip 10.0.75.0 0.0.0.255 any log
access-list 101 permit ip host 10.0.65.16 any log
access-list 101 deny ip any any log
Thks,
Paulo Maur?cio
