Warning message
ASA5520 redundant ISP on virtual interfaces
Oct 17th, 2006
Is it possible to implement redundant ISP's with failover firewalls using virtual interfaces and the ISP connetions? I have a 5520 with the standard number of interfaces and want to create virtual interfaces on the outisde interface?
jwjohansen Wed, 10/18/2006 - 13:02
When you say virtual interfaces are you talking about sub interfaces?
These can each be a different vlan and can be monitored for failover etc...
cpembleton Fri, 10/20/2006 - 05:53
  • Silver, 250 points or more
The interface tracking in that version brakes when using a failover pair. The tracking works until failover occurs. Then a reboot of both firewalls is required to fix the tracking.
Bug: CSCsd51407
Dual ISP fails after failover, routing table have stale routes
A new release is coming soon to fix the bug. 7.2(1) is the only version out that supports tracking.
Chad
