Warning message
Deny UDP reverse path check from ....
Oct 18th, 2006
%ASA-1-106021: Deny UDP reverse path check from 172.19.60.219 to 172.19.60.255 on interface outside
I have seen this syslog messages, when i connect with vpnclient.172.19.60.0/24 is my inside.
How can i solve that issue,
casco
Overall Rating: 5 (1 ratings)
m.sir Thu, 10/19/2006 - 01:28
  • Gold, 750 points or more
It means that outside interface recieved packet from network that is NOT in firewall routing table...
Its enabled with command
ip verify reverse-path interface outside
You can disable this feature with command
no ip verify reverse-path interface outside
Do you know what is 172.19.60.x network???
M.
Hope that helsp rate if it does
cascolibre Thu, 10/19/2006 - 07:02
Thks.
172.19.60.x is my inside network block.
But there is no route from inside to outside already.
stalin_cisco Tue, 05/22/2012 - 22:46
Hi Friends,
I'm also getting this logs on my ASA firewall,
%ASA-1-106021: Deny UDP reverse path check from 10.67.3.113 to 10.67.254.66 on interface inside
Both Ip address are not in my network... Please help me how i can trace the IP address ?
Thank you,
Stalin P
Haitham Jaradat Wed, 05/23/2012 - 05:44
  • Cisco Employee,
Can you share the following information:
1. NAT configuration.
2. interface configuration.
3. VPN client pool used.
4. routing table from the ASA.
