Warning message
Converting from CatOS to IOS on cat6500
Oct 19th, 2006
I converted my switch to the IOS successfully. For some reason my msfc is now missing, what did I do wrong? When I do issue the sh module command, I am missing the module 15. Please advise.
amikat Thu, 10/19/2006 - 10:53
  • Silver, 250 points or more
the "sh mod" output is slightly different in the (native) IOS as compared to hybrid (ie.CatOS). There is no module 15 construct within IOS. You should see your msfc however under submodule display. E.g. you see your supervisor within the modules part of the output in position 5 and beneath under the submodules part of the output you should see both the msfc and pfc as submodules (as submodules for the module in position 5). I hope my English makes sense.
Best regards,
Antonin
pmpesha Thu, 10/19/2006 - 12:12
I don't remember seeing any submodules under the mod 5. I will verify next time I go to the lab. Will the msfc be accessible? and how? Thank you.
