Warning message
Scheduling AP reboots with WLSE
Answered Question
Oct 20th, 2006
Is there a way to schedule a reboot of specified APs? No firmware updates or reconfiguration issues here - just scheduling a reboot. Thanks.
Correct Answer by frankzehrer about 10 years 10 months ago
Hi Carlo,
just define a new IOS-template in "Configure -> Templates" a new template named e.g reload_APs and enter the following in the "Costum Values"
reload
y
Then save this template.
Change to the Tab "Jobs", create a new jobtype "Config Regular" enter a jobname e.g reload_1131 and click on "Config Job".
Then follow the steps.
In Step 2 use the previously created template reload_APs and proceed with the steps 3-5.
I have tested this with my 1200, 1231 and 1242.
It is working fine.
Best regards,
Frank
P.S. Pleas rate helpfull posts
Overall Rating: 5 (1 ratings)
Correct Answer
frankzehrer Mon, 10/23/2006 - 01:33
  • Silver, 250 points or more
Hi Carlo,
reload
y
It is working fine.
Best regards,
Frank
