Warning message
Multiple VLANs on L2 switch
Answered Question
Correct Answer by glen.grant about 10 years 10 months ago
Yes you can create multiples but you have to remember they will not be able to talk between them without a layer 3 device doing the routing.
Correct Answer by Adam Frederick about 10 years 10 months ago
You most certainly can!!
Create them through global config or VLAN database mode; I prefer global config, below is an example;
Router(config)#vlan 2,3,4,30
This will create VLANs 2,3,4 & 30.
Overall Rating: 5 (2 ratings)
Correct Answer
Adam Frederick Sun, 10/22/2006 - 18:28
  • Bronze, 100 points or more
Correct Answer
glen.grant Mon, 10/23/2006 - 03:33
  • Purple, 4500 points or more
