4948 10G
Oct 23rd, 2006
Looking to purchase a 4948 10G to support wireline gige copper speeds and eventually 10G down the road for testing in a lab for triple-play. We're looking to push upto 1,024 IPTV streams for an immediate need, and eventually add data and 8k-16k voip streams. Will the 4948 10G be able to handle line rate traffic, or have any buffer limitations?
We have a 6506 currently and using it primarily as a PE switch, but we'd need to upgrade from SUP1a to SU2-720 and additional blaeds that are out of our price range.
Any ideas, soulutions or will the 4948 10G handle this?
brispin Fri, 10/27/2006 - 11:51
Buffer limitations are always there but in this case i feel that the set up should be fine
